Atari Boy
Which Ht Lead Goes Where?
Atari Boy
My 1.6 has been converted to a 1.9 and I need to work out which HT lead go to which dizzy terminal and cylinder .
I have done a search and can't anything relivant.
Any ideas, photos diagrams would be appreciated, I can’t wait to get it out on the road.
Jonny
McPikie
Same as the 1.6 I would imagine
Atari Boy
I was told that they are different and cunningly even if they are I have taken the 1.6 ones off the head.
Help, someone pleeeeeeeeeeeeeeease.....
Have you tried a search?
This has been posted (with pictures showing the order) plenty of times before.
Its the same order on the 1.6, 1.9 & Mi16 though.
Atari Boy
I have tried a search and the search engine hates the HT bit.
DirtyFlare
see as I'm nice,
check this LINK out
Atari Boy
Dirty, thank you but the link does not work, but below has it covered.
old topic
Sorted, I hope.
Jonny
Edited by Atari Boy
Minimum search string length is 4 when using FullText Index enabled database which might explain why trying just HT or HT leads didn't work.
steve@cornwall
- top lead outside of cap goes to plug 3rd furthest from dizzy, king lead obv. below this. next lead down goes to plug 4th furthest from dizzy ( by cam cover) back lead at bottom of cap goes to plug 2nd from dizzy, with the top lead at rear of dizzy cap going to plug closest to dizzy. Clumsy way of putting it but hope it helps. If you leave the leads on the cap, they are obvious according to length
Atari Boy
Thanks Graham, I get there in the end!
DirtyFlare
the link works for me, but maybe its because you arent signed up to psooc forums
