sutol
Drilled Discs
sutol
Going to drill my own discs :D
How many holes you think or should I dimple or both ?
swordfish210
I'v never thought that drilling discs was entirely nessacary, it's just weakaning the disc and adding lots of places where cracks could form. You'd be better off getting some ATE powerdiscs
sutol
ATE powerdiscs are expensive and grooved, which is worse grooves ,dimples, or holes ? :D
swordfish210
well you can get a bit of pedal vibration with groved discs, but it's better than a drilled disc that is more likely to crack in my oppinion
Batfink
drilled disks really are not needed anymore as pads dont produce gases like they used to 20 years ago. All you will do is weaken the disk
GLPoomobile
Didn't you say your disks were 50 quid? I'm pretty sure ATE powerdisks are cheaper than that.
sutol
38 quid including vat, ,,
I'm undecided about me dimples now :D
large
I would NOT get drilled disks as a mate of mine hade them and within a month he had cracks coming frim the holes.
sutol
Right, sound advice all of it.
Seeing as I have made up a template for drilling 15 holes in the disc (and very accurate it is too) I,m going to drill dimples in them because they look racey :D and I wont have been wasting my time with the calipers and protractor and jig saw etc..
Thanks. :lol:
Tony_205
What are you using to drill them ?
sutol
A normal metal drill bit and a stand drill. :wacko:
mmt
Drilled my 307 brakes. Raced them for a whole season. No craks at all.
About 40 holes in each disc. Works fine on the track!
My 5 p.
/Martin
sutol
My 5 p.
/Martin
OOHHH, that'll rattle the cages of the "you should always wear a crash hat on a mountain bike" brigade. :D Your discs will break up and you will die :)
Rippthrough
Daft thing to do imo.
