Martin W
Holding Up The Fuse Box
Martin W
I've come accross a problem, I have removed the lower part of the dash as its not needed in a track car but I dont have a way of holding up the fusebox anymore, as seen in the pic. How do other people keep the fuseboard up?
Any ideas welcome.
Jrod
I took the little slidey thing off and put a cable tie through the hole and up around a bracket under the dash.
humanz
Sorry to resurrect a year old post but...
I have a ph1 dashboard, and the catch where the fuseboard hooks on has broken. I'll give the method above a try, but does anyone have any other suggestions on how to hold up the fuseboard? would really like to be able to close my glovebox.
DRTDVL
i've got a peice of string tied to the dash bolt hole area with a loop on it to hold it up
They always are! There should be a little metal folded springy catch attached to the fuse board, and where this locates to secure the glovebox up onto the dash, the dash is more often than not worn/broken away. I try to bend the metal catch and/or mount is slightly off centre to the board so that it pops onto a new part of the dash, hopefully working for a while again!
Re-wire the car as you don;t need half of it anymore :) and you can have a nice 6 way fuse box then.
But you can get a tube/bar and have a R clip at the bottom
hispetdog
cable ties keep it light!
DamirGTI
Ditto ! cable ties for me too :)
Damir
humanz
Well, so far, the cable ties have been working wonderfully. Thanks guys.
Wouldn't mind more info on the tube/bar Miles. Just out of curiousity.
calvinhorse
i use a bungee cord, plent of places to hook it :huh:
