Elad
Valve Seals
Elad
someone asked in a local forum if it's possible to change the valve seals (TU3JP engine) without removing the cylinder head,
I was thinking:
if you put each piston in TDC (so that the valves don't fall into the cylinder)
if you then compress the valve spring and remove it
you then can replace the valve seal
return the spring
do the other valve
go to the next cylinder and put it in the TDC etc'...
makes sense?
Elad.
boombang
some people have said about blowing compressed air through spark plug hole to keep valves up too.
I've done it before on an Mi16 with a length of bent copper pipe inside spark plug hole to hold up valve.
Had just put a head on an engine and a mate dropped a small screw into the top, where it dropped down beneath the valve spring on the left exhaust side...
stu_woac
to get to the valves your undoing the head bolts anyway so your kinda taking the head off in a sence,
