joe1joe 3 Posted January 13, 2008 (edited) what is your opinion of the 205 dimmas hanldling characteristics as they are around 70mm ish wider on the back than the front, obivously comparing it to a 205 with the same spec suspension setup etc, as im thinkin of using mine for track days but i am a bit unsure what it would handle like being alot wider. (only makinging it wider with the wheels) If i was to use mine i was thinking of using a set of 17" wheels with a 15mm-20mm wheel spacer on the front and longer stubaxles and and spacer, on the rear(40-50mm), would rather have 15" wheels but have a set of 17" superlight wheels with bf goodrich pilot tyres doing nothing, this would then put less load on the wheel bearings and could run lighter wheels than the dimma ones?? and it would also be 7" inch wide wheels all round aposed to the 7" front and 8" rear found on the dimmas,which would mean less unsprung weight, and also makes tyres expensive for the dimma wheels, and they seem a bit big for a lighweight 205,or just rip the kit off!!!!!! Edited January 13, 2008 by joe1joe Share this post Link to post Share on other sites
jackherer 543 Posted January 14, 2008 or just rip the kit off!!!!!! You could but you might not like what you find - http://www.peugeotdimma.nl/forum/viewtopic...d0893dbc5f2ef0e by the way the fourm topic title was ment to be "dimmas handling characteristics" but enterd it into the wrong post but im new! and u cant edit the topic title Title edited. Share this post Link to post Share on other sites
joe1joe 3 Posted January 14, 2008 thats realy bad for a 205, the kit has hidden every thing! my car is a solid example of a 205 with no rust and the kit has only been on it for 1-2 years as it not genuine kit, so i no there no rust hideing under the kit,and is the same width as a dimma. and since putting a 1.6 16v in there i realy want to use it for track days! Share this post Link to post Share on other sites
GTI6BOY 29 Posted January 14, 2008 I got a dimma with a 309 rear beam so its even wider, and the handling is unreal. and also makes tyres expensive for the dimma wheels Dimma wheels came with 205/45/16 all round as standard I just purchased 4 x eagle f1s for £280 delivered Thats not expensive imo Share this post Link to post Share on other sites
Guest Tommy Posted January 14, 2008 Hi Joe1Joe Bit off topic but which 16v unit did you fit Share this post Link to post Share on other sites
joe1joe 3 Posted January 14, 2008 tu5jp out of a 106 gti (1997) with my orginal xs box with a later bell housing. post some pics if u want? Share this post Link to post Share on other sites
Guest Tommy Posted January 14, 2008 Yes please Going to fit 16v shortly with seq gearbox for rallycross/sprint car to stay in class Could be very helpful any info you have on the conversion or any problems you suffered I would say it flies with the xs box Can't recall the ratios or cwp but a friend of mine used same box in a 106 for sprints with good results Many thanks in advance Share this post Link to post Share on other sites
