Guest petrie82
Fitting Suspension?!?
Guest petrie82
Hello
Im currently fitting my new bilstein shocks as we speak. As i was dismanteling the old strut i knackered the bump stop in the process. I was just wondering if you actually need it?
ginjaspeed
It's advisable to keep the bump stops, as this stops the damper from undergoing adverse load when the suspention goes to full compression. Without them you could damage the dampers!
Sandy
If you're fitting "Streetline" ones yes, but Sprintline and Challenge dampers have internal bump stops. The original ones don't fit the inverted damper arrangement.
Guest petrie82
Yeah i'm fitting sprintline, yeah i noticed yeah would not fit.
Cheers for that i was about to order brand new ones!!!!
