steendp 0 Posted January 12, 2008 Hi. Well, the subject says it all. Does an ABS driveshaft fit an non-ABS vehicle (205 1.9 gti) ? The non-ABS driveshafts seems to be difficult to source locally to me. Thanks! Steen Share this post Link to post Share on other sites
mossy 0 Posted January 12, 2008 Hi steen I would say yes as the only difference is the outer joint casing has a ring of teeth cut into it for the sensor to read. Also to note I needed a new hub carrier and Peugeot only sell the ABS style. ( Slightly different casting with hole drilled for the ABS sensor) HTH Al. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted January 12, 2008 Yes they do Share this post Link to post Share on other sites
steendp 0 Posted January 12, 2008 Excellent. Thanks for you reply! Share this post Link to post Share on other sites
