newdean0
Rear Beam Rebuild Part Numbers
newdean0
Hi all,
Since it's such a common thing to have to do I'd have thought there'd be a post somewhere with part numbers required for a rear beam rebuild but the search function says no.
To save me the pain of trying to explain over the phone to the man at Peugeot does anyone know the part numbers I'd need to rebuild a 309 gti rear beam? I'm looking to just replace the seals (both the metal tube ones between the tube and trailing arm and the ones on the ends of the anti roll bar). I can't imagine the parts are different to 205 numbers.
Also, for future reference if someone has the parts for the bearings and bearing shafts could you also stick those up as I'm sure someone else will need them.
Cheers,
Dean
