davemar 16 Posted January 9, 2008 I've just been looking at 'er indoors car after it's been away for no repairs (had a ding and written off with fixable damage), and noticed the fuel gauge was at the bottom when I started it up. I'm pretty sure it had some fuel in it when I handed it over, and would expect the warning light to come on if it was low. So either the petrol has been drained, or the fuel level sensor has stopped working (or the wiring in between or the gauge). I see there are three wires on the sender unit (under the rear seat), does anyone know what each one is, and what voltages I should be reading on them assuming half a tank? Is there a non-messy way of checking the fuel level, so I can rule out an empty tank as the problem? BTW, it's a 205 1.1 H-reg. Share this post Link to post Share on other sites
DaveW 6 Posted January 12, 2008 you could just remove the sender in the tank and dip a stick into the tank to see how much is in it. lift the back bench up to find 2 rubber circles the smaller on is the sender. Share this post Link to post Share on other sites
davemar 16 Posted January 13, 2008 DaveW said: you could just remove the sender in the tank and dip a stick into the tank to see how much is in it. lift the back bench up to find 2 rubber circles the smaller on is the sender. I can see the sender but can't see how to remove it, I can't see any bolts or anything? Share this post Link to post Share on other sites
DaveW 6 Posted January 13, 2008 sorry bud i dont know either, maybe it twists off? Share this post Link to post Share on other sites
