Jon_Bmw 13 Posted January 8, 2008 Right this is on a 405mi16 2.0, not our 205 mi16. It seems when one works, the other has a tantrum and decides not to work Its my brothers car and i'm trying to get it fixed for him whilst he is skiing. Nice huh? He went to drive to the airport and went to start the car and he said it sounded like it had no compression and assumed he had snapped the cambelt. Anyway we checked the cambelt tonight, its all fine and timed up correctly using the bolt hole technique. Total worst case scenario is that it is one tooth out, but i'm 99% certain it is spot on the money. So we took the plugs out and did a compression test expecting to see one cylinder right down. Results: Cold test(obviously): 1) 4 bar 2) 4 bar 3) 4 bar 4) 4 bar WHAT the f**k is going on here then? It seems unlikely that the gasket has blown and all four cylinders are foobarred at the same time. With the throttle held wide open it is worth noting that they made 6 to 7 bar, but all consistant. Now the starter motor has always been fairly lazy on this car, turning over quite slow. So my question is. Could a slow/worn starter motor cause the low compression results? As it doesn't seem to be as fast at going up the gauge as our 205 mi16 engine. That shots up like a rocket, where as this is fairly slow to a measly 6 bar To me it seems unlikely that the valves are bent as the timing all looks spot on. The cambelt and tensioners are less than 2 years old as well. So is it an unrelated problem or is something f**ked. It certianly doesn't sound right when starting it, sounds like no compression and indeed there is very little. But it still doesn't spin very fast for no compression in my opinion. Ideas guys? Jon Share this post Link to post Share on other sites
M_R_205 5 1 Cars Posted January 9, 2008 it could be the slow starter stoping it from firing, and also giving the low presure, the slower the starter the more time the air has to escape from the cylinder on the compression stroke..., try a good one, off your car Share this post Link to post Share on other sites
Jon_Bmw 13 Posted January 9, 2008 Yeah We have another one spare, although its untested. I just can't help thinking its not solely the starter motors fault. Something doesn't sound right. Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted January 10, 2008 could be the lifters holding the valves slightly open, have you tried tow starting it? Share this post Link to post Share on other sites
Jon_Bmw 13 Posted January 11, 2008 could be the lifters holding the valves slightly open, have you tried tow starting it? This is what we thinking about trying, but due to various logistical issues will be a right pain in the ass I am being midly retarded as its been a long day at work, would whipping off the rocker cover show us anything amiss? Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted January 12, 2008 This is what we thinking about trying, but due to various logistical issues will be a right pain in the ass I am being midly retarded as its been a long day at work, would whipping off the rocker cover show us anything amiss? no it wouldnt unfortunately. ford zetecs used to have trouble with this a few years back. no compression on a cold morning. changing the oil for 5w30 and a bump start usually sorted them out. try changing the oil and filter and try to start it again. Share this post Link to post Share on other sites
