stuart 31 3 Cars Posted January 8, 2008 I've tried posting in the wanted section but it won't let me until I have made 50 posts so please don't delete this thread. What it is, I am currently making up the solid brake lines on my rally car project but need some of the flexi brackets from on the rear beam as mine doesn't seem to have any... I have one from the passenger side trailing arm which I got with a new caliper but am still missing the drivers side bracket. I could also do with the ones that fit on the lower damper bolts but have made some from ally angle that will do for now. If nobody has any of these, can you get them from peugeot? Cheers Stuart Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted January 9, 2008 You need 30 posts to allow you to post in the wanted section. If you are staying with rear drums the brackets you need are fitted to all 205s on the rear shock lower mounting bolt but the disc ones are disc braked car specific. You can probably still get them from peugeot as a similar bracket is likely used on new Pugs even now but the lower mount one could be modified to fit with a vice & drill. Graham. Share this post Link to post Share on other sites
stuart 31 3 Cars Posted January 9, 2008 Cheers for the reply, I have actually made a couple of L-brackets already for the ones near to the lower damper bolt out of 3mm ally angle so just need the o/s bracket from near the caliper now. I'll try peugeot as you mention to see if they still sell them. Thanks again Stuart Share this post Link to post Share on other sites
