mechsmurf 0 Posted January 7, 2008 evrey cold start car will fire first time and idle normally for 15 secs thjen idle will drop till it dies then have to restart and rev till warm and then will be fine Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted January 7, 2008 Do yourself a search, this is a really common problem and has been covered lots of times. All the answers are out there waitring for you. Share this post Link to post Share on other sites
mechsmurf 0 Posted January 7, 2008 have been searching for last hour only things i have found are missing bolt from oil filler which i know i have and sad valve which i will be checking tomoz is there anything else or could someone give me a link to topic like this sorry for the hassle Share this post Link to post Share on other sites
Astra Dan 0 Posted January 7, 2008 Missing bolt from oil filler? Is this the one towards the back that holds it to the inlet? This was a 6mm hole straight into the inlet on mine, caused all sorts of starting/ idling probs till I found it and plugged it. Share this post Link to post Share on other sites
