sussex_gti 0 Posted January 5, 2008 What do people find easiest? need to know soon, as im taking mine out in about an hour! I'm thinking letting the enine down on to some tyres. As soon as someone answers, feel free to delete the thread! Cheers, Chris. Share this post Link to post Share on other sites
Alastairh 47 Posted January 5, 2008 Easier to take it out the top if you have a hoist Share this post Link to post Share on other sites
ORB 227 1 Cars Posted January 5, 2008 Yes, I took the last one out from above. The one before, I cut it out with a big petrol grinder That was cool Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted January 5, 2008 Its a case of six & two threes imo. If you have use of a hoist & load leveller you can take the engine & box out from above easily but if not dropping it out of the bottom like you say onto tyres is simple enough as one assembly if you remove the subframe. I've done them both ways & there is very little difference in difficulty or time either way. Graham. Share this post Link to post Share on other sites
whizzer71 0 Posted January 5, 2008 Out the bottom m8,remove front bumper rad assy etc,o/s/f wing,driveshafts and all the related high pressure pipes etc,make sure you undo the pressure relief valve on the hydraulic accumalator to avoid any nasty injuries. Fold the two metal pipes that run from under neath along the bottom of the bell housing backwards once you have undone them from the accumalator,remove all the related pipework to the LHM tank and pump etc ,disconnect services (wiring,coolant pipes,exhaust fuel lines,gearlinks,clutch cable etc)support engine from underneath and undo mounts lower out bottom of car ! Tris . Share this post Link to post Share on other sites
sussex_gti 0 Posted January 5, 2008 Cheers guys. Tris, im sure you spend 99% of your time on here! Am going to drop it out from the bottom, nearly there. Im doing at work so using a 2 poster lift. Tris, why do i need to take the wing off? Share this post Link to post Share on other sites
Banjo 1 Posted January 5, 2008 Thats where the wiring loom runs on a bx Share this post Link to post Share on other sites
sussex_gti 0 Posted January 5, 2008 Ahh, gotcha. I'll be taking that off then! Cheers guys. Share this post Link to post Share on other sites
whizzer71 0 Posted January 5, 2008 Cheers guys. Tris, im sure you spend 99% of your time on here! Am going to drop it out from the bottom, nearly there. Im doing at work so using a 2 poster lift. Tris, why do i need to take the wing off? Yeah dont you know it ! Share this post Link to post Share on other sites
Phil H 16 Posted January 5, 2008 My votes is get the angle grinder , whip off the slam panel and the metal at the bottom and take it out of the front. Share this post Link to post Share on other sites
sussex_gti 0 Posted January 6, 2008 All out, had to remove the inlet manifold, but this is coming off anyway before the engine goes in the gti. a quick wiggle and out she came from the bottom. The joys of a 2 poster ramp! Cheers all. Share this post Link to post Share on other sites
