osama
Turns Left When I Brake...
osama
and turns right when i accelerate? ever so slightly! but when im doing 80+ and i ease completely off the accelerator its very noticable and jerks to one side? any ideas guys?
almost certainly dead bushes on the front wishbones, or the balljoints on said wishbones.
occasionally the hole where the balljoint locates in the hub carrier wears into an oval shape.
OR, it could simply be a loose bolt somewhere in the aforementioned components.
dan9
Mine does this too... but ever so obviously!
Seems to be common from reading this forum, and main cause appears to be wishbone bushes. That's the first place I'll be checking...
osama
thanks for the help! what does fitting new bushings involve? a whole new wishbone? how much should the components cost?
thanks again
osama
Bushes can be replaced on the wishbone but if its the balljoint a new wishbone is required.
Best place for a wishbone bush kit is Peugeot, you need part # 3599 07 which costs about £15 but has enough new bushes & replacement bolts for both wishbones not just one.
The wishbone bolts often don't get tightened correctly, they should be tightened when the car is back on its wheels at the normal ride height not when the front of the car is off the ground. Doing them this way puts stress on the bushes instantly & causes them to wear out quickly.
osama
cool! as im getting the car up a ramp on sat to clean and seal the underneath, i will get my mechanic dude to have a look! :wacko:
thanks for your help
osama
timb1046
hey osama, if you want any help doing the bushes i did the ones on my pug (which is now back on the road). you've got my number, if not billybob/wilkey have it.
Tim
kyepan
all you need is a butane blow lamp, a punch , possibly chisel, and a big persuader, and some copper grease to put them back in
Spiky
also
i could be your drivers side fron brake caliper not working :) or not working as good as the passenger side
osama
cheers time, ill see what my mate says on sat! if it is them, ill give you a bell!<br>
yeah i did think about one caliper not working as well as the other...but that maybe wouldnt solve the accelerating to one side?
cheers
osama
