skinner2k3 3 Posted January 3, 2008 I have found a 205 with non-opening rear windows down the scrappy. I want the window rubbers and to get the glass out to make a template for cutting Polycarb. Do I need any special tools to remove the rubber/glass without damaging it? Cheers Share this post Link to post Share on other sites
Jrod 7 Posted January 3, 2008 Nope. I just do it with my fingers and a bit of washing up liquid to get them back in. Share this post Link to post Share on other sites
skinner2k3 3 Posted January 3, 2008 Nope. I just do it with my fingers and a bit of washing up liquid to get them back in. So I can get them out of the car at the scrappy with just my fingers? Share this post Link to post Share on other sites
Jrod 7 Posted January 3, 2008 Yep. Just pick at the rubber around the inside bottom while pushing the window (gently!) once you most of the bottom bit off the metal you should be able to get it out. Share this post Link to post Share on other sites
daza4 24 Posted January 3, 2008 Or push with both feet like I did when I got my rear window seals!!!! Share this post Link to post Share on other sites
skinner2k3 3 Posted January 3, 2008 Oh, OK. I will try that. Did I mention the car is at the top of the stack! Might ask them to get it down before I get inside and start pushing windows out Share this post Link to post Share on other sites
Jrod 7 Posted January 3, 2008 How high a stack? any less than 5 and you are a wimp. Share this post Link to post Share on other sites
skinner2k3 3 Posted January 3, 2008 3....I'm a wimp. If they stacked them 5 high I wouldnt even go in there! Share this post Link to post Share on other sites
jeremy 71 Posted January 3, 2008 I tend to give up when I start to notice my head is in the cloud Seriously I might go two high but five high is just plain crazy. Share this post Link to post Share on other sites
skinner2k3 3 Posted January 8, 2008 Well, I had the car put on the deck for me in the end. I got the rubbers out ok, but I dont think the scrap yard will make much money on the glass now! Gave up trying to lever them out as it was cold and raining, so put a screw driver under the edge and levered until....pop goes the window! Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted January 8, 2008 All you need is a mate to catch the glass for you, get in the car lay on the back seat, both feet flat on the glass, towards one of the corners, and then just a firm but controlled "push" and the glass will push out of the rubber intact, ready for your buddy to catch it for you. Share this post Link to post Share on other sites
skinner2k3 3 Posted January 8, 2008 All you need is a mate to catch the glass for you, get in the car lay on the back seat, both feet flat on the glass, towards one of the corners, and then just a firm but controlled "push" and the glass will push out of the rubber intact, ready for your buddy to catch it for you. Ah well, maybe next time. Actually thinking about it it was in the scrappy and full of various bit of car and broken glass from the rear hatch, plus I was on my own. Going to have to be a bit more carefull fitting the Polycarb windows as I dont want to break them if I can help it. Share this post Link to post Share on other sites
