309PUG
Trap Door
309PUG
Looking from the front of the car which way does the drap door flap open on XU10 sumps ?? is it towards the flywheel or crank pulley end ?? I have seen pictures on this forum but have been unable to 100% confirm which way it opens.
Chris
Edited by 309PUG
Rob Turbo
It opens towards the pulley end
Stu
As above, mine opens towards the cambelt end, i think the idea is that between the door and pump baffle the majority of the oil is kept in the centre part of the sump and hence near the pickup.
Dont forget that if you keep the ally spacer/stiffener (if its a 1900 or Mi) the pickup will need to be extended.
