dean 0 Posted December 30, 2007 when I did a gti 6 conversion I re-sprayed my engine bay so everything was taken out. I have come tonight to put the brake light in and I forgot to rivet the bracket that holds the bias valve on the insdie of the chassis leg. On the passenger side. and now that the engine is in I cant get a rivet gun to rivet it pack into place. Is there any other places to mount this that will be easier than lifting the engine out. Share this post Link to post Share on other sites
sutol 0 Posted December 30, 2007 Is it possible to get the rivet gun under the wing and do it that way. If the hole in the bracket is too big stick a washer on it. Share this post Link to post Share on other sites
dean 0 Posted December 30, 2007 for the size of the rivets you need a long rivet gun and you cant fit it in because of the gearbox Share this post Link to post Share on other sites
sutol 0 Posted December 30, 2007 for the size of the rivets you need a long rivet gun and you cant fit it in because of the gearbox I meant take the wheel off and look at it from that side then rivet it on back to front or inside out or from inside the wheel arch . Leave the valve where it is, just do it from the other side and put a small washer over the exposed end of the rivet in the engine bay for it to bite on. Or have I got the wrong end of the stick again Share this post Link to post Share on other sites
dean 0 Posted December 30, 2007 cheers i will try that i didnt think of doing it that way cheers mate Share this post Link to post Share on other sites
