mogsman 2 Posted December 29, 2007 Hi all, just need some info on how to fit my new gearbox mount. I've looked at the Haynes joke book, but still no clearer. All I know is that the battery and tray are removed. Many thanks Ian Share this post Link to post Share on other sites
welshpug 1,663 Posted December 29, 2007 you wont be able to fit your new mounting with the battery tray removed as it is part of the bracket. refit the battery tray/gearbox mounting bracket, the stud on the gearbox should poke up through the middle of the bracket, raise the gearbox up with a trolley jack and place the new mounting onto the stud. Fit washer with cutout, fit 18mm nut. lower gearbox so that mounting fits over the 2 studs in the bracket and fit the 2 13mm nuts, try and get the studs central in the slots. hope that helps, I couldn't find any photographs of mine though I'm sure I took some! Share this post Link to post Share on other sites
mogsman 2 Posted December 29, 2007 Cheers for that. Any idea what the torque settings for the middle nut and the two outer ones are? Ian Share this post Link to post Share on other sites
