Martin W 0 Posted December 26, 2007 I've removed the heater and matrix etc from inside the car and now I have the hole over the bulkhead that I need to block off. How have other people covered this? I was thinking of a thick piece of plastic and a large jubilee clip to cover/seal it. Is there a better way? Thanks, Martin. Share this post Link to post Share on other sites
smighall 1 Posted December 26, 2007 Ah good point, i've just removed mine too and hadn't thought that far yet lol Share this post Link to post Share on other sites
Martin W 0 Posted December 26, 2007 Ah good point, i've just removed mine too and hadn't thought that far yet lol I've just got the heater 'hole' and sunroof 'hole' to fill now. Sunroof is easy with a sheet of ali. I just want it to be properly water tight as the hole left from removing the heater is right above the fuse box! Share this post Link to post Share on other sites
welshpug 1,677 Posted December 26, 2007 for quite a while I thought you mean where the hoses go through the bulkhead Martin bit of ally and silicone sealant do the trick? Share this post Link to post Share on other sites
jonnie205 1 Posted December 26, 2007 ally sheet and some panel bond or rivit Share this post Link to post Share on other sites
Miles 331 1 Cars Posted December 26, 2007 Yep, I just used a thin sheet of steel, Bolt's and some RTV. Never leaked in the 6 yr's I had it Share this post Link to post Share on other sites
Martin W 0 Posted December 27, 2007 Yep, I just used a thin sheet of steel, Bolt's and some RTV. Never leaked in the 6 yr's I had it Thanks everyone, a sheet of ally and some panel bond it will be (plus bolts if needed). Share this post Link to post Share on other sites
