Sloppy 0 Posted December 24, 2007 recently got an s16 engine which starts ok but ticks over lumpy, when reved it sound ok but not quite right, nothing like bottom end (had one go before) and head is nice and quiet. Guy i bought it off said it did not start, but i have got it started fine? turned over a bit but then fired... Others i have had tick over spot on and the engine only has a genuine 75k, i was lead to belive this is the headgasket begining to fail as it only has 75k but is on a m reg so it quite old... are there any other characteristics to the gasket failing so i can properly diagnose whats wrong with it. Cheers Share this post Link to post Share on other sites
welshpug 1,676 Posted December 24, 2007 dodgy coilpacks are quite common on these. only way to tell is a compression test and pressure test on the cooling system Share this post Link to post Share on other sites
Sloppy 0 Posted December 24, 2007 will check coil packs, guy who i got it off remved rad so there no cooling system to check which is anoying! Share this post Link to post Share on other sites
Sloppy 0 Posted December 28, 2007 HELP. Any help or symptoms anyone else had would be greatfull as i would obviously rather not rip the head off the car to look... Share this post Link to post Share on other sites
