danpug
Which Turbo?
danpug
It looks like the turbo (XU10 turbo/manifold) i was going to use on my project engine may be duff. Instead i'm going to purchase a TT manifold but need to find a suitable turbo. Engine is going to be a 1.8 bottom end, 405 sri head running off a DTA. I'm clueless with turbos so any suggestions will be great. Thanks.
whizzer71
T2 type ,25 or 28,if you go for a 28 you'll have to swap the servo for a diesel or Xs type for clearance as its damn tight,Is possible though and we'll be fitting a T28 with tt manifold to one in the new year and running it on emerald .
danpug
What car do they come off? Will any t28 fit?
whizzer71
T25's are fitted on many applications be carefull which one you get as some of the Ford ones have the wastegate built into the exhaust elbow,The T28 we have obtained was an upgrade for a Nissan 200sx,although some of them have them fitted as standard,I dont know anything about Nissans so couldnt tell you exactly what model to go for ,and again they all have variations from model to model,Ie size of compressor housing,exhaust housing and at which angle the wastegate actuator is mounted,Its a bit of a mine field really !.
Do a search on here theres loads of pics and threads from where people have done conversions previously
danpug
Any opinions on the one in the link above?
whizzer71
Cant get into It mate
Tris
Edited by whizzer71
ORB
Try this - Item Number - 220183671316
Edited by ORB
danpug
Thanks. On second thoughts the turbo in the link dosen't state what name it is so i assume its probably cheap and nasty!
whizzer71
220183671316 ,that'll be ideal !
danpug
For sure? The thing that concerns me is that its not a garrett.
tom_m
an a/r 48 compressor t25/gt25 would be ideal. it will take a lot of work to get an a/r 60 compressor to fit right and would probably be larger than ideal for a 1.8.
look for the t25 from the c18det, that would be suited to your engine size and fit easily
Edited by tom_m
danpug
Link isn't working, this is one i was looking at earlier but surely for that price they must be poor quality? Anybody have any experiences (real not assumptions) of these? Are they fragile?
Edited by danpug
matty_gti
140192488997 - Item code.
I thought it was on the cheap side and would like to know also has anyone had any experiences with these?
Matt
