205mattgti 0 Posted December 22, 2007 how usable are the Helix paddle clutches on the road i am looking at getting one along with a mi16 lightened flywheel cheers Matt Share this post Link to post Share on other sites
ajm-e30 0 Posted December 22, 2007 iv never had a problem with them but can be difficult if not used to them mate Share this post Link to post Share on other sites
Sandy 191 Posted December 22, 2007 Sharp and occasional judder, but reliable and once you're used to it, normal clutches feel horrible! Share this post Link to post Share on other sites
saveloy 8 Posted December 23, 2007 (edited) For road use a paddle will judder and vibrate on take up. You will need to dial in more revs than you are used to to pull away. I think they are horrible on road cars. On top of that, a paddle will wear prematurely, compared to an uprated organic plate. My friend's paddle (on his 205TT) lasted 7000 miles! Whereas my organic Helix has done around 30,000 miles, so far. Edited December 23, 2007 by saveloy Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted December 23, 2007 whats the best race clutch to go for on a 205?! and what sorta priuce u lookin at?! thanx simon Share this post Link to post Share on other sites
Sandy 191 Posted December 23, 2007 That's odd on the wear, because cerametallic friction material is generally harder wearing than organic and certainly has been my experience on the cars I've used them on. I accept that not everybody likes the take up, but it's usually exacerbated by using an uprated cover, where as I use standard covers to retain the friendly feel. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted December 23, 2007 For a road car I would favour the Organic plate over the padel, I;ve used and supplied allot of Organic plates and yet to have a problem, Share this post Link to post Share on other sites
McPikie 0 Posted December 23, 2007 Miles, what kind of price are you charging for a decent uprated clutch?? Share this post Link to post Share on other sites
saveloy 8 Posted December 24, 2007 sandy309 said: That's odd on the wear, because cerametallic friction material is generally harder wearing than organic and certainly has been my experience on the cars I've used them on. I accept that not everybody likes the take up, but it's usually exacerbated by using an uprated cover, where as I use standard covers to retain the friendly feel. That's the difference. With the uprated cover the extra pressure over heats the friction plate. The paddle types aren't designed for stop/start traffic. They simply wear quickly because of the extra heat. Share this post Link to post Share on other sites
205mattgti 0 Posted December 24, 2007 where is the best place to get the clutches from and what pressure plate should i use all help appricated matt Share this post Link to post Share on other sites
Sandy 191 Posted December 24, 2007 Unless it's a boosted engine, the OE pressure plate will suffice. UK dealers for Helix are Mardi Gras and Demon Tweeks IIRC. Also check out the OMP plates from YB Racing, I've heard good reports on them recently. Share this post Link to post Share on other sites
205mattgti 0 Posted December 25, 2007 thanks all do i use the standard release bearing as well Share this post Link to post Share on other sites
Sandy 191 Posted December 26, 2007 Yes, but a slightly deeper one is sometimes advisable to take up the slack from the different fingers position, or it'll rattle a bit at idle. Share this post Link to post Share on other sites
205mattgti 0 Posted December 26, 2007 sandy309 said: Yes, but a slightly deeper one is sometimes advisable to take up the slack from the different fingers position, or it'll rattle a bit at idle. where do i get one of them from cheers Share this post Link to post Share on other sites
Sandy 191 Posted December 26, 2007 Not sure for the BE boxes, but on MA's the 1.4 one is thickest. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted December 26, 2007 All the same on the BE's unless you go for a multi plate clutch Share this post Link to post Share on other sites
