calvinhorse 870 Posted December 20, 2007 my brother put an idea too me, seeing as i have a 106 xsi for breaking could i use the managment instead of 205 xs dizzy setup? just for the spark not the fueling as i have carbs. thanks and Merry Christmas! Share this post Link to post Share on other sites
RossD 44 Posted December 20, 2007 calvinhorse said: my brother put an idea too me, seeing as i have a 106 xsi for breaking could i use the managment instead of 205 xs dizzy setup? just for the spark not the fueling as i have carbs. thanks and Merry Christmas! I expect the advance curve will be all wrong for the XS engine, the XSi has bigger valves, different valve timing, higher compression all of which mean a completely different advance curve. You would also have to use an XSi flywheel unless you could rig up a crank trigger some other way? Its probably more work than the end result is worth! Share this post Link to post Share on other sites
calvinhorse 870 Posted December 20, 2007 sorry ross, im using the xsi engine box and flywheel Share this post Link to post Share on other sites
welshpug 1,675 Posted December 20, 2007 that makes it silly not to then! Share this post Link to post Share on other sites
RossD 44 Posted December 21, 2007 welshpug said: that makes it silly not to then! Definatly! Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted December 21, 2007 how big of a job do you think it is? Share this post Link to post Share on other sites
welshpug 1,675 Posted December 22, 2007 same/similar to an Mi wiring conversion I'd imagine. engine bolts straight in and use 205 driveshafts if I'm not mistaken. Share this post Link to post Share on other sites
