calvinhorse 870 Posted December 18, 2007 how have you done this or how do you advise doing it? do i need to block them on the inside of the ports? thankyou for looking Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted December 18, 2007 Machine some alloy plugs that fit snugly into the injector bosses, have someone TIG weld them in place. Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted December 18, 2007 cheers tom, just a cap or a similar shape to the injector ie deep? Share this post Link to post Share on other sites
calvinhorse 870 Posted December 18, 2007 oops, my bro left himself logged in! cheers tom as above!! Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted December 18, 2007 Probably best to make it so as it can be TIG'ed from both sides, so as deep as reqd to reach through. Share this post Link to post Share on other sites
Rippthrough 98 Posted December 18, 2007 Unless your cheap like me and epoxy a couple of 10p pieces in. Share this post Link to post Share on other sites
calvinhorse 870 Posted December 18, 2007 lol i was thinking something like that but was worried about the pressure blowing them out when it backfires! Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted December 18, 2007 I'd be more worried about the chav's nicking your injector blockers to spend on white lightning! Share this post Link to post Share on other sites
Rippthrough 98 Posted December 18, 2007 I'd be more worried about the chav's nicking your injector blockers to spend on white lightning! You would be, you live in Rother.... Oh, hang on. Share this post Link to post Share on other sites
Peetypug 5 Posted December 18, 2007 (edited) buxtons not that bad.... but the pigeons do carry flick knives for protection Edited December 18, 2007 by sorrentopete Share this post Link to post Share on other sites
Dream Weaver 2 Posted December 18, 2007 When I did this for my bike bodies I just drilled and tapped the injector holes, then used some screw in brass blanking plugs and some PTFE tape to ensure a seal - has worked fine since. Share this post Link to post Share on other sites
Sandy 191 Posted December 18, 2007 Welding them in is a bit extreme, the heat can cause problems. Epoxy glue is as effective if it's clean and It's not mega difficult to knock them back out if you need to later. Likewise, threading it rules out using injectors in the head at a later date. I've used ex carb heads/manifolds on injection engines several times and so had to "undo" the plugging. Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted December 18, 2007 Ive used tiger seal to bond copper piping across mine which is then used for the brake servo Share this post Link to post Share on other sites
