24seven
Grilles
24seven
simple really. is the base model grill the same size/fitting as the GTi?
Jrod
Yes.
24seven
ta :)
Paintguy
The same size and fitting yes, but iirc the backing is not as 'open' as the GTI and diesel ones, so they let less air through to the radiator.
Arahan
Yeah the backing is all solid, no airways through to engine bay or anything!
craig f90
Ive heard about this too. It would be easy enough to modify if you cant get one, surley? The bars clip on and off if you can get a GTI backing.
sonofsam
From what I've seen down the breakers, the backing's are all the same, it's the actual grille bars that are different and yes solid!
Jrod
I stand corrected. <_<
