BERTMAN
Yey! A Rear Beam Thread
BERTMAN
i went to put 1 of my rear beams onto the xs the other day when i noticed that the two cross members dont sit parrallel, so that when i went to mount it to the car the crossmember brackets dont fit into the holes in the chassis, its as if one of the things ive circled below has rotated round slightly? how do i go about getting them straight?
Liam
ill take a picture of the beam tomorrow
Edited by BERTMAN
check that both the crossmember brackets are of the same type, 1.6 ones have the studs central fore and aft, 1.9 brackets are offset by 10 mm IIRC.
so if you have a 1.6 and a 1.9 mount, or two left/right hand 1.9 mounts they wont bolt straight up.
BERTMAN
the brackets themselves are ok, there both off a 1.9 axle that was on the car previously its as if the circled bit is rotated round on the beam tube? if that makes sense... its hard to describe so ill post a picture up soon, but any other ideas?
aaah right, ummmmmm!
they're just pressed onto the tube so its possible they could have moved with a heavy enough impact, if you lay the beam on the floor upside down you should be able to see if they are out of alignment at all.
ORB
Yay!!!
You cant touch this!!
de Noir
.... its as if the circled bit is rotated round on the beam tube? if that makes sense... its hard to describe so ill post a picture up soon, but any other ideas?
Possible scenario... although I don't see how could this happen in normal use.
Is there any play between cast part and beam tube?
In short, to save further trouble > You'll need a large press to sort it. First, cast bracket off, realign and then back on. This works for sure.
BERTMAN
well it has been in storage for a while and it was in the boot of my car down sum quite fun country lanes on the way home when i got it :) ... and as i dont have a big press should i just take it to a local garage?
de Noir
I would.. That's exactly how I got sorted mine... Assembled from 3 different rear beam parts.
...but again, it's mystery to me how your beam got misaligned at all! :)
Bally
Its happened to me. I just got a really big hammer and a couple lashes and lots of cussing later it was fine
