miamistu
Driver's Door Won't Close
miamistu
Hi,
Got up to go to work today and opened the drivers side door. I was a little forceful as it was frozen and I heard a crack or a snap when it opened. Now it won't stay shut - the locking mechanism doesn't hold it in place as if the handle was in the open position.
I've not got a haynes to hand and a forum search has revealed nothing.
Does anybody know what's gone wrong?
It's not too urgent as I ended up walking to work (in the freezing cold! :)) so can't check it out properly until tonight.
Thanks,
Stuart :lol:
TT205
Over the years I've gone to work several times with the door held shut with rope - it's always been because it's frozen - shuts fine when temperature warms up a bit!!
never made a nasty snapping noise though
steve@cornwall
Check that the lock pin on the body hasn't become loose - may have moved inwards when shutting the door with a tight (frozen) mech
miamistu
I'm praying that's the case. I'm hoping the noise was just ice breaking when I opened the car :)
It's not the pin on the body, I has a look at that. It's definately the door - if I shut the mechanism with a screwdriver it doesn't stay in the locked position. :lol:
hengti
sounds like a door card off job - there are several bits of plastic in the door that operate the locking mechanism which are connected via a stiff wire rod - could be one of the plastic assemblies has snapped and released the rod or the rod has otherwise come free - ?
sorry - really difficult to explain and visualise but should be obvious(ish) how it works once you've got the door card off
miamistu
Arse - If it's not fixed itself when I get in tonight I'll whip off the card and have a nosy :)
Simes
You may get away with just removing the trim around the handle before removing the card itself.
miamistu
Huzzah, I don't have to do anything - the magic car fairy fixed it while I was at work :D
Looks like TT205 was right :)
check that the handle itself is returning properly, the outer bit normally does but not the inner.
