mr2haz 0 Posted December 9, 2007 The central locking on my 205 does not work. The boot servo was seized so I removed the servo but the rest of the central locking does not work either. I have a replacement boot servo to fit. What else should I investigate to get the central locking fully working? Share this post Link to post Share on other sites
welshpug 1,666 Posted December 9, 2007 (edited) depends if its a factory fitted kit or an aftermarket one. does it work off the plip or the key in the drivers door? a common fault with the door locks on a 205 is that the handles seize up, and the mechanism inside doesn't drop back down when the motor tries to lock it, are you getting any noise at all when you try to lock? check to see if you're getting a signal to the motor by putting a bulb in each connector to the motors and activating the system. Edited December 9, 2007 by welshpug Share this post Link to post Share on other sites
mr2haz 0 Posted December 9, 2007 When I purchased the car I was not given a plip. It is a 1990 Gti 1.9 so I am assuming it is fitted with central locking as standard. When the key is turned I do not hear any sounds of any motors attempting to work or anything. I removed the servo in the boot which looked original fit. This had seized preventing the unlocking of the boot. Share this post Link to post Share on other sites
welshpug 1,666 Posted December 9, 2007 not many 205's had standard central locking at all, though many did have it fitted as an option. is there an alarm fitted at all? Share this post Link to post Share on other sites
daza 0 Posted December 9, 2007 depends if its a factory fitted kit or an aftermarket one. does it work off the plip or the key in the drivers door? a common fault with the door locks on a 205 is that the handles seize up, and the mechanism inside doesn't drop back down when the motor tries to lock it, are you getting any noise at all when you try to lock? check to see if you're getting a signal to the motor by putting a bulb in each connector to the motors and activating the system. My central locking opens all the doors but will only lock the drivers door,so it could by the handles like you mention do i need to put wd40 on them? Share this post Link to post Share on other sites
Gentrix 2 1 Cars Posted December 9, 2007 to both of you. Check your door harnesses and if you have the connection-plug between door and body for broken cables or a (what is the english word for "durchgescheuert" ?) sign of a worn-through loom. andi Share this post Link to post Share on other sites
jackherer 543 Posted December 9, 2007 (what is the english word for "durchgescheuert" ?) frayed apparently. Share this post Link to post Share on other sites
Gentrix 2 1 Cars Posted December 9, 2007 frayed apparently. that´s what google told me, but the backtranslation came different, anyway - thanks andi Share this post Link to post Share on other sites
jackherer 543 Posted December 9, 2007 a google image search for frayed wire gives this: so I think it is what you mean Share this post Link to post Share on other sites
mr2haz 0 Posted December 9, 2007 The second set of keys I was given did include an alarm fob, looks like a Cobra system. I have never tried using it or even know if it works. I know the immobiliser works though. Share this post Link to post Share on other sites
mr2haz 0 Posted December 29, 2007 I replaced the locking servo in the boot today. Now if I operate the driver side door lock the boot also locks/unlocks. I guess all I will need to do now is replace the servo for the passenger side door. Share this post Link to post Share on other sites
Dan@bar 0 Posted January 11, 2008 Hi there, I'm going to revive this central locking thread rather than start a new one (hope thats ok). When I got my Pug back in March 07 it had central locking which I assume is a factory fit standard/option system. When I unlocked the drivers door the boot would unlock but not the passenger door. I had a Cobra Cat 1 alarm/immobiliser fitted for the insurance which gave me a remote fob that locked and unlocked the drivers door and boot. I figured that either a bit of wiring or a new actuator/servo would sort out the passenger door at some point. But now my drivers door is playing up. Sometimes when I unlock it with the fob or key the locking makes the normal noise but pulling the handle doesn't open the door. Sometimes re locking and unlocking sorts this out but not always, leaving me with the undignified task of unlocking the passenger door with the key and climbing across to the drivers seat So having read a few threads, do I need to free up and grease the mechanisum then replace the actuator get the drivers door working properly and maybe do the same again to get the passenger door to join in the party? If the actuators are the cause of my central locking problems, will the boot actuator falue soon too? Also, at the moment I can't get the drivers door open at all! Has anyone got any ideas of how to get the door open to get the door panel off?! Cheers Share this post Link to post Share on other sites
ledders 1 Posted January 11, 2008 (edited) This must be a very common fault with 205's my one in the winter only just locks and unlocks itself with out any warning, really bad if you leave your car to warm up in the morning and can't get into your car!! Anyway sorry dude can't help with your but thought I'd also see if anyone had a clue about mine... Ledders. Edited January 11, 2008 by ledders Share this post Link to post Share on other sites
