Dan Ingram
Battery Relocation
Dan Ingram
Wiring really isnt my strongest point and i'm going to move my battery to the boot. I wil be putting it in a box which seems the safest idea. What cable size should I use, am i best using 135amp ish or will it be ok with something smaller? Also do I just earth the battery in the boot or do I need to run the earth back to the engine. If I do earth it in the boot wheres best to earth it?
All help greatly appreciated :angry:
ants1974
I used some outdoor 3 core stuff drom b&q, seems ok, hasnt got hot with all the cranking i've done to get it started :D
Ryan
135amp is about as thin as I'd use. Ideally you'd use something thicker - in the 180-200amp range at least.
engine killer
I have done almost the same but I cannot remember what size of cable I am using. Regarding to the earthing, I run three wires one to the closest point (underneath passenger seat), one to engine and one to ECU in order to avoid any bad earthing.
Sandy
Because of the distance, I use 180A. You feel the benefit if you have a large/high CR engine.
large
I used some outdoor 3 core stuff drom b&q, seems ok, hasnt got hot with all the cranking i've done to get it started ^_^
What!!!!!!!!!!!!!!!!!!!!!!!!!!! :o
What size cable have you used, I would change that asap.
ashley peddle
for the earth i just run one of the halfords pre-made connectors to the boot (they have a battery terminal on one end and a ring connector on the other)
Alastairh
If its going in the boot in a box, i would just run the earth down to one of the 17mm beam mount nuts ^_^
As Sandy says, 180 sounds about right :o
ants1974
What!!!!!!!!!!!!!!!!!!!!!!!!!!! :lol:
Its rated at 260amp, its shielded and i used all the cores and the shield, my electrician mate says it will be fine.
Stu
260amp A.C or D.C? the cyclic nature of A.C may well mean it can handle 260amps, but id say it'd struggle with that amount of D.C.
Still, so long as its beefy enough it should be ok. :lol:
Ryan
200 amp cable is normally 25mm^2. I doubt a bit of AC power cable is going to be more than 6mm.
Spiky
i used 300 amp battery cable from www.vehiclewiringproducts.co.uk
dont both with small crap stuff
use a good size cable and forget about it :)
snillet
I started with 35mm2 cable but that turned out to slim here in the cold north, so now i´m using 50mm2 cable, works just fine.
Although i have something like 11:1 CR..., that should crave some more.
snillet
i used 170 amp stuff from CBS (http://www.nfauto.co.uk/consumables.htm) i also ran an eartht o the engine bay as there was some odd feed back through the dash
25mm2....That is less then the first cable i tried.... and half of the one i´m using now, if you have cold starts a lot (about +/- 0 degrees C and down) that is not going to be good.
large
Whats ok then ;) What size is it, 16mm square is good for 95A ac. A.C. and D.C are not the same. By the sounds ot it you may have s.w.a. cable this is not trirated(sp?). It will probably be ok, (please note the word probably)and if its not your car will catch fire but thats up to you i@m just trying to help you BEFOR that happens :lol:
Spiky
i used
Ref ......Cable size.. mm2 ....O.D......... Amps....... £/ metre
315 ......315/0.40 .....40 .......11.8mm .....300 ..........£3.86
snillet
i used
I would say that is about the right stuff.
There is tons of info about correct cable sizeing in the motorboat communities if anyone like to read up on it.
In motorboats the batteries generally are located far from the engine.
Spiky
use a good size cable and forget about it :(
thats where i got mine
