Spiky
Problem After Fitting New Rear Discs And Pad
Spiky
I bought some new discs and some new pads
i have now fitted them, problem i have is that the disc CANT turn now :?
i first though the disc had the wrong off set, but it's identical to the old one, as i checked
then i thought, maybe the pad is thicker,
we it is but only becuase it's new :?
now if i ground down the outter pad i'm sure it would be ok,
but the pads are brand new ds3000's and dont want to fook them up, espcially if i dont grind them square
any idea's?? :? :?
RossD
Did you wind the caliper back?
Spiky
the inner pads not even touching it, the piston is 100% not the issue :rolleyes:
Craigb
if you take the pad out , is the caliper sliding freely ?
Spiky
i think so, but cant be sure,
will check when i get home :rolleyes:
Edited by Spiky
swordfish210
check that the sliders haven't seized
If the piston isn't touching the inner pad then all you need to do is slide the whole caliper body outward so the piston closes up to the pad and you have a bit more clearance for the outer pad. As it hasn't just naturally slid into that position it suggests your sliders are a bit gummed up.
Peetypug
^^^^^^^its defo this^^^^^^^^
had the same problem on my 306, the caliper wasnt sliding freely
Spiky
cheers for the replies guys,
will be looking at these thursday when i get a free night in the garage :)
hate this time of the year at times as i'm so busy, with visting, birthdays and parties :)
Discostu
is it fixed yet?
Spiky
yeah
sliders greased up by my ne slave bitch :(
Powers
Bastardo!
Spiky
go make tea biatch :) ....lol
