ants1974 0 Posted December 5, 2007 My car starts perfectly but wont rev over 2500, just dies like the spark has been cut. Tried AFM and CTS, Fuel pressure seems ok but i havent tested it, had a new coil,new crank sensor (to sort earlier problem)No air leaks apparent at the manifold. I'm lost. Please help. Bear in mind this engine has been running since this morning as i've only just finished wiring/piping etc. Share this post Link to post Share on other sites
ORB 227 1 Cars Posted December 6, 2007 ignition amp?? is it timed up correctly?? Share this post Link to post Share on other sites
taylorspug 7 Posted December 6, 2007 Try ignition amp first, maybe the throttle position sensor and also the wiring to the AFM (pin it back to the relevant places using a multimeter to check continuity, presume you have a loom wiring diagram?) Share this post Link to post Share on other sites
lee-bg 0 Posted December 6, 2007 It may sound stupid. but remove air filter so that you can look at the AFM flap...and if possible remove AFM CAP and loook the needle that moves there on a track. then push the throttle body open so that i REVs, does the Flap move at all ? and will it REV that way or same problem ? Share this post Link to post Share on other sites
ants1974 0 Posted December 6, 2007 I checked the AFM, it moves fine, if i move it manually it makes a difference to the running, i have already tried another one. I got an ignition module today, a brand new one and it doesnt even fire, i think i'm just unlucky. Try again tomorrow. Share this post Link to post Share on other sites
lee-bg 0 Posted December 6, 2007 what do u mean by 'if i move it manually' ? The AFM or the Throttle cable ? Share this post Link to post Share on other sites
ants1974 0 Posted December 6, 2007 stick my finger in and move the flap, the flap moves as it should with the engine running. Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted December 7, 2007 Have you checked crank sensor, also try swapping the ecu temp. Share this post Link to post Share on other sites
ants1974 0 Posted December 7, 2007 It would seem the gti and mi16 wiring are completely different, looks like the loom i got was wired for the gti ignition amp, anyone know which wires i swap around on the ignition amp? Share this post Link to post Share on other sites
ants1974 0 Posted December 9, 2007 Ignore that last post, they gave me the wrong amplifier. Fitted new amplifier today, exactly the same. Also changed fuel pressure regulator and tps, no difference. Any more suggestions? Share this post Link to post Share on other sites
ORB 227 1 Cars Posted December 10, 2007 fuel pump relay? coil? ht leads? Share this post Link to post Share on other sites
ants1974 0 Posted December 10, 2007 Trying an ecu tomorrow, had a new coil and i've bridged the fuel pump relay and nothing makes a difference. I'm lost. I have 3 fault codes but no idea what they mean, 91,92,93 Share this post Link to post Share on other sites
Stu 18 Posted December 10, 2007 I had a similar problem with a Rover, the TPS had gone down on it, so id start there. Its dead easy to check, if its adjusted right it should 'click' just as the throttle opens, have you got a multimeter? Share this post Link to post Share on other sites
ants1974 0 Posted December 10, 2007 changed that yesterday, still no luck Share this post Link to post Share on other sites
ants1974 0 Posted December 11, 2007 I think i may have found the problem. The AFM loses its feed voltage when the engine is running, as i have now replaced the ecu i know it cant be that. Must be a loom problem. I have already checked the wiring, must happen under load. If i dont fix it tomorrow i have a nearly finished mi16 turbo 205 for sale. Share this post Link to post Share on other sites
danpug 1 Posted December 11, 2007 Don't give up just yet after you've come so far, unless you want to sell it cheap to me! Share this post Link to post Share on other sites
ants1974 0 Posted December 12, 2007 can anyone tell me why i have only 2 volts at pin 3 of the afm? i should have 5 and i've checked the wiring to the ecu. Share this post Link to post Share on other sites
ants1974 0 Posted December 13, 2007 I dont know if any of you have looked at my website, but when i bought this engine (on ebay) it was listed as engine/loom/ecu and ancillaries, but the W^&%&R who sold it me had sold the ecu and loom. I have just realised today that he didnt tell me "Sorry mate i sold the airflow meter and substituted it with this 205gti one which is completely different". If he had said that in the first place i wouldnt have spent 2 weeks and 200quid trying to fix something that didnt need fixing. Never mind, i'll tell you tomorrow if it runs with the correct AFM on it. Share this post Link to post Share on other sites
welshpug 1,657 Posted December 13, 2007 arsebiscits! Share this post Link to post Share on other sites
danpug 1 Posted December 13, 2007 I'm really starting to get sick of ebay, sooooooooo many muppets on it. Share this post Link to post Share on other sites
ants1974 0 Posted December 15, 2007 (edited) Runs perfect. There's a lesson here, always check you have the correct parts and some goon hasnt tried to rip you off. Dont use PUGPARTS205 or PUGPARTS on ebay! Edited December 15, 2007 by ants1974 Share this post Link to post Share on other sites
