ronnie_gti
205 Gti Turbo Conversion
ronnie_gti
cheers for that cray_legs. just ordered an s16 flywheel to go on to this. intercooler i ordered. all i have to do is order the clutch which i proving to be the most expensive part as i would like tobuy an uprated one due to aving redoing it in the future.
Crazy-legs!
Another thing you're going to need Ronnie, is some high-tensile M7 bolts for the cluthch cover plate. As the S16 flywheel uses a different size bolt to the 205 flywheel. (I found this out when trying to fit the clutch on my GTI6 flywheel!)
hope this helps,
Marc.
hope this helps,
Marc.
Those M7 clutch cover bolts are so expensive too.
ronnie_gti
how many do i need and anyone now the part number? 7? bit of a random size.
cheers
Crazy-legs!
From memory i belive its six you need. i cant remember the length off the top of my head, but i just brought some from a motor-factors and cut them down to size. Make sure they are the correct tensile strength though, i think i used 8.8.
Marc.
sonofsam
I wouldnt say £7.50 plus postage for 25 bolts was too bad! http://www.ecas2cvparts.co.uk/find.asp? :)
Yes it's 6 you need and they^ didnt need cutting :D Just type M7 into the search on that site , page 2 of results, Set screw, plated, 11mm hex head, M7 x 20mm.
Edited by sonofsam
ronnie_gti
no problem. they are now ordered ;)
where do/can i order a valeo or Helix Uprated organic plate and cover from? been looking on google but just pick up loads of random stuff.
cheers.
hopefulle i should have everything order and coming thru the post now. just the waiting side of things.
Discostu
Valeo manufacture original equipment Peugeot clutches so u'r main dealer can get you one.. .. or go to u'r local motor factors to get the same clutch for half the price :(
Hi-flow heads can supply Helix clutches
ronnie_gti
need the upper mount. but anyone got one layin aound. its only the bracket from tthe engine as have an 306 xsi mount comming to bolt onto the munt on the engine.
cheers.
Discostu
So u need number 1 in that diagram?
If so i have a mount lying around i'l have to check it to see if its the same
ronnie_gti
yer thas it. sorry forgot toput that. yer no1, if you had one that would be a great help. conversion starts on janarury 8th. havng the engine bay sprayed and degrased at the same time. i'm also issing the altrernater and brackt plus starte moter but can i use te ones off the gti?
ronnie_gti
anyone?? if not any able to take a uess to how much from pug?
craig f90
Sonosam used the bottom pulley, altenator ;) & belt and 205 starter motor. :D Iirc. <_< You have tou modify the belt tenoner to get it to fit. If you do a search, there are loads of topics from both turbo coversions and gti-6 conversions on here.
Discostu
I also use a gti starter motor and the alternator is from my mi16 (as it was brand new at the time) just fabricated a simple bracket from angle iron. As for the engine mount u need, the one i have isnt the one sorry fella
ronnie_gti
i got this diagram from peugeot service box
bt nyone know the part number for the bracket, haveing a few problems trying to find it. went t pug today and they are n help at all without a vin number. grrrrrr
Rob Turbo
1807 88 - Mount that will fit an mi16 type mount (exactly the same as number 1 in the first picture) - £148.39
1846 75 - Mount that will fit a 306 type mount - xsi, s16, gti6, not the same as your last picture, it's the one in the picture below- £47.18
Both prices inc. vat
Edited by Rob Turbo
ronnie_gti
you are a star fella. cheers, thats a great help.
now i can get on with the task on hand lol
ronnie_gti
Thought i'd better update this a lil.
parts bought so far:
flywheel s16 : 30
upper mount : 30
slimline rad fan : 40
VSS : 12
polybushes (just for reassurance) : 50
intercooler : 60
engine (plus pug1off loom, a spare gearbox, and ecu) : 250
still to buy:
new gaskets (for reassurance to check everything is fine)
mi16 valeo clutch
lower part of mount
ecu unlock
pipework for intercooler
pipework for water cooling
406 brembo's plus 307 hdi discs
and fitting and everything still do to, god it gonna b a nice winter thing to do lol
M@tt
ronnie i have a complete mount as pictured in Rob Turbo's pic above, not sure if its the one your after. I got it in error as i actually needed a mi16 top mount and not that one as i have an XM engine not 406. I've got both the bit that bolts to the block and the top mount
PM me if its of any use
Jamal
ecu unlock
Hi Guys!
Maybe it's a silly question. Why the ecu have to be unlocked?
Thanx,
Jamal
M@tt
because it won't run the engine otherwise
Jamal
What do you mean by that?
Have to kill the immo, or what should I have to do?
sonofsam
Yes, the ECU will be locked by it's immobiliser, so the engine will not run.
Usuall route is to either send the ECU away to be unlocked, or buying one thats been unlocked.
Do you still have the Donor car/keypad/code/transponder etc? as it can be unlocked if you have a combination of those things<
Jamal
Oh this is the only problem?
I have a doc that desrcibes the method how to unlock it. Something to do with one of the ECU's pin and a +12V, and my friend succesfully unlocked his engine.
I've tought that would be a bigger problem.
Edited by Jamal
Jamal
Now I know, that my last post was stupid. Wiring is not enought.
I have got the keypad and the code too, but I want to leave it out.
