stue205mi16
Central Locking
stue205mi16
has packed in :wacko: fuses are all ok so im guessing its the motor?? am i right in saying its in the drivers door???
ORB
do the leccy windows still work??
stue205mi16
yes windows are fine,it actually worked again today then stopped,now thats surely a loose connection but where do i start :)
ORB
the motor and work back.
Phil H
Taking a guess at the age of your car, I would say it is the grey control unit in the drivers door that has given up, it looks like a motor and is attached to the door lock pin, but is operated by the key and is simply a control unit and not a motor...unless you have remote locking....
stue205mi16
its an 87,stipped the door card off today and it has got the grey control unit,the fault is itermitent though,may just get a new unit and stick it on anyway ^_^ off topic phil,did you used to own a diablo 306???
Phil H
Yeah, just lob another grey control unit on.
And you are quite correct, the wife used to have a Diablo 306, which has now evolved into a red Picasso....babies and all that ! I'm sure we met with PSOOC at Harvester on Grange Park
M_R_205
Wha exactley happens when your central locking dosent work? as mine is intermitent and i can hear the controll unit buzzing away in the door when it decides not to work, im asuming phase 1 and 2 are different as i fitted a motor from a phase 2 which is black and made it stop working all together :S
Edited by M_R_205
stue205mi16
yes we have,i thought i recognised the name!! dont dom the meets anymore,since having our second child i stop the old group leader stuff and nosw the group has collapsed without me :D ah well,life goes on and all that :)
stue205mi16
when i turn the key i get nothing at all,it just opens the drivers door,then the next time i turn the key it works fine :) im gonna replace the unit when i get five minutes :D
