Headling 0 Posted December 4, 2007 Hi Guys, Whizzer 71 is half way through my 2.0 8v turbo conversion ( 2nd turbo engine! dont trust scrap yard engines mine was junk! ) and I need various gaskets etc for it. Is it best to get them from a motor factor like LCP's? Or is there any good on line engine spares places? I need: Cam Cover Gasket cam belt kit inlet manifold gasket cam seal zx xu oil pressure switch water housing gasket between head and housing thermostat and o ring pair of diff seals 1.9. thanks in advance. Share this post Link to post Share on other sites
Headling 0 Posted December 4, 2007 well kind of answered my own question (with a bit of help from whizzer 71), found GSF and LCP very helpfull, just having troubles with the diff seals? I have a std 1.9 diff from a 1990 car, the motor factors have said there are 2 sizes of seal 1 x 58mm OD 1 x 47mm OD And they do them in two different types of materials. Does any one have any ideas as to which is right?? Share this post Link to post Share on other sites
Rob Turbo 3 Posted December 4, 2007 You need one of each size, the small one is for the drivers side and the larger one is for the passenger side I can't help with what material to go for? I'd guess that the more expensive one would be harder wearing? Share this post Link to post Share on other sites
dale205mills 39 7 Cars Posted December 4, 2007 I have tryed seals from gsf and seals from peugeot, i would allways say buy seals and gasket's from peugeot the prices are not bad and they are a better fit in my book. Share this post Link to post Share on other sites
danpug 1 Posted December 4, 2007 205parts sell them on ebay for £6 delivered per pair. Share this post Link to post Share on other sites
