Guest turbopete
1.6 Cam
Guest turbopete
hi there ive got a 205 gti engine out of a c reg 205 and ive got a cam from an 87 205 gti 1.6 would swapping these give me any improvenments?
Have a look on the block by the upper engine mount for the engine ID tag (small silver & black tag), its possible they are the same engine so there's no point.
If the tag is there there will be a three digit code on, either 180A or B6D. If its a B6D then its the later 115bhp engine which is possibly the same as the 87 D reg one but if you don't have the ful;l engine to check I simply wouldn't bother.
If the engine is a 180A then you'll be better to fit the whole head from a later model for the bigger valves.
Graham.
