rnotman67 0 Posted December 3, 2007 I am planning on running my 205 Mi16 on bike throttle bodies and plan on using one of those Megasquirt ECU's (not read up on all the gumf yet) But What am i going to need to fit these and What is needed to get Mi16 running? If anyone knows the rough costs in £££ as well then that would be most appreciated. Cheers folks! Share this post Link to post Share on other sites
Guest hassan Posted December 5, 2007 (edited) you need only the ECU and its connector with wiring, you can use your injectors and ECT sensor and triggering from ignition coil -ve terminal or from your CKP sensor if you have v3.0 board and you have to get a TPS to tune based on it, another suggestion to minimize cost if you order the megasquirt ecu as a kit you don't have to order the map sensor with the kit as you don't need it when tuning based on TPS signal. Edited December 5, 2007 by hassan Share this post Link to post Share on other sites
