Pugnut 9 1 Cars Posted December 1, 2007 found a mint rear panel in a scrappy and i'm going back this week to remove. any tips on getting one off in one piece? iirc last time i did one i broke it . regards, Al Share this post Link to post Share on other sites
large 33 Posted December 1, 2007 Just change the boot lid Share this post Link to post Share on other sites
jord294 95 Posted December 1, 2007 (edited) underneath 'peugeot' '205' 'gti' etc badges are 4 clips which slide over rivets which are fastened in boot lid and hold plastic trim on if you remove badges first, you can't go wrong Edited December 1, 2007 by jord294 Share this post Link to post Share on other sites
Pugnut 9 1 Cars Posted December 1, 2007 underneath 'peugeot' '205' 'gti' etc badges are 4 clips which slide over rivets which are fastened in boot lid and hold plastic trim on if you remove badges first, you can't go wrong thanks, i remember now! cheers, Al Share this post Link to post Share on other sites
Roman 0 Posted December 2, 2007 if it glue'd on surface... no way in one piece Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted December 2, 2007 Check inside the hatch for a small pin that comes through the hatch near the lock, it sometimes has a clip on the back & will damage the panel if you don't notice it. Graham. Share this post Link to post Share on other sites
GLPoomobile 958 Posted December 2, 2007 .....and then once you've removed all clips and the lock barrel, you need to carefully slide the panel downwards while easing it over the rivets that the clips were fastened too. The edge of the panel is delicate so take care as you slide it off to avoid cracking it. Share this post Link to post Share on other sites
craig f90 0 Posted December 2, 2007 I would take a wall paper scraper too. Incase its double sided taped on, mine was. just run it around the edges before you slide it off. Share this post Link to post Share on other sites
Pugnut 9 1 Cars Posted December 3, 2007 wish me luck then!!! Share this post Link to post Share on other sites
M_R_205 5 1 Cars Posted December 3, 2007 wish me luck then!!! I was just about to ask this question!! Good luck Share this post Link to post Share on other sites
