ChrisB
Steering Wheel.
ChrisB
I can move the steering wheel and column up and down about an inch and a half. shouldn't there be something to stop this happening?
yes it should be bolted up tight into place by 4 10mm nuts!
ChrisB
I'll check them then cheers.
ChrisB
Ok, i've checked the 4 bolts and they're nice and tight, but i've still got movement, any other ideas?
Jrod
Has the bit it bolts to snapped off?
GLPoomobile
Are you sure you checked the right place?
IIRC there are two fixing points which can easily be confused if you aren't looking properly.
