ChrisB 0 Posted November 26, 2007 I can move the steering wheel and column up and down about an inch and a half. shouldn't there be something to stop this happening? Share this post Link to post Share on other sites
Baz 421 Posted November 26, 2007 yes it should be bolted up tight into place by 4 10mm nuts! Share this post Link to post Share on other sites
ChrisB 0 Posted November 26, 2007 yes it should be bolted up tight into place by 4 10mm nuts! I'll check them then cheers. Share this post Link to post Share on other sites
ChrisB 0 Posted November 27, 2007 Ok, i've checked the 4 bolts and they're nice and tight, but i've still got movement, any other ideas? Share this post Link to post Share on other sites
Jrod 7 Posted November 27, 2007 Has the bit it bolts to snapped off? Share this post Link to post Share on other sites
GLPoomobile 958 Posted November 27, 2007 Ok, i've checked the 4 bolts and they're nice and tight, but i've still got movement, any other ideas? Are you sure you checked the right place? IIRC there are two fixing points which can easily be confused if you aren't looking properly. Share this post Link to post Share on other sites
