Goliath
What Turbo Will Fit A 205?
Goliath
hi, did a search but came up nowt. im wanting to buy a turbo to fit my 1.9 205 and wondering what turbo would fit? i can get a garrett t2 quite cheaply and wondering if this would fit?
cheers guys
just found this one on ebay going pretty cheap or so it seems http://cgi.ebay.co.uk/Mitsubishi-Evo-Subar...1QQcmdZViewItem
also what should i look for in a turbo? eg what spec and psi and inducer size?!
Edited by Goliath
brianthemagical
depends which manifold you use and how much power your after.
kyepan
in garret terms most 2.0l cars use gt25 and upgrade to around gt28rs or 3037,
any bigger and they do not have enough air flow to spin up and produce positive boost until further up the rev range too Smaller turbo will spool up quicker but be more restrictive at high rpm.
smaller engines seem to use gt20's or other stuff.
was reading this click, about the changes that engine manufacturers make to their cars before turbo charging, worth bearing in mind if you want your car to be able to run higher boost.
Goliath
im after about 60 bhp if that is possible but i dont really mind to be honest! any idea where i can get a turbo manifold or do they need to be custom made?
cheers
Ryan
www.205parts.com sell Turbo Technics-style manifolds.
danpug
You could just fit the exhaust manifold and t25 from a 2.0 8v turbo, henry yorke saw nice results from this and it works out quite cheap compared to other turbo conversions. He used the 2.0 management as well.
tom_m
cheers
i've got a spare turbo manifold. PM me if you're interested.
