Guest silver 1600 Posted November 24, 2007 Hi all not posted on here for a while But i have a bit of a problem with my GTI the heater blower stopped working last week so i went to the breakers and got a new one and all was fine for a week . Then last night i went out to the car to start it up to clear the screen of frost and it worked fine then but when i came out ten mins later it had stopped again . Thought nothing of it as it may be the fuse and went home had a look today and the fuse is fine and the motor dose not seem siezed up to any Ideas? Thanks guys if you can give me any pointers as its getting bloody cold now Share this post Link to post Share on other sites
jord294 95 Posted November 24, 2007 this time of year, and if you can afford one, buy a new one i recollect them to be about 70 squid though Share this post Link to post Share on other sites
brianthemagical 1 Posted November 25, 2007 have you tried testing the input to the blower? to see if it is the blower or controls? Share this post Link to post Share on other sites
Guest silver 1600 Posted November 25, 2007 Yeah im gonna check the feed this morning if I can find my test lamp Share this post Link to post Share on other sites
yeti-dj 7 Posted November 25, 2007 My gti heater died the other day as well and it turned out to be the resistor unit that sits under the dash next to the blower had give up, new one fitted and heater now blows far harder than before, all good at this time of year.. yeti Share this post Link to post Share on other sites
Paintguy 0 Posted November 25, 2007 My heater can be a bit temperamental, and it's caused by the wiring connection going into the resistor block mentioned above. I reach down and give it a wiggle and the heater comes on until I hit another big bump. Share this post Link to post Share on other sites
Super Josh 4 Posted November 25, 2007 My heater can be a bit temperamental, and it's caused by the wiring connection going into the resistor block mentioned above. I reach down and give it a wiggle and the heater comes on until I hit another big bump. I've had this, one of the pins on the speed controller module (aka resistor block) was a little corroded and the increased resistance caused it to heat up, due to the amount of current being drawn. And it actually caused the plastic housing on the end of the cable to melt Share this post Link to post Share on other sites
mrblonde 0 Posted November 27, 2007 im having probs with my blower to.where is the resistor?.it just seems to work when it wants to. Share this post Link to post Share on other sites
westy 0 Posted November 29, 2007 me too Mine just seems to run slowly. Ideas? Share this post Link to post Share on other sites
Atari Boy 11 Posted November 30, 2007 I too have blower problems, I though it was fcuked but it came back to life today. Am I right in thinking that I probably need to clean the resistor's terminals to start with? Share this post Link to post Share on other sites
James_m 0 Posted November 30, 2007 Previous thread Some good advice from RobbieCFC here. My heater used to run slow/occasionally not at all, so i bent the arm, and all is well now. Albeit with only the last 1/4th of the dial doing anything, but ive never seen a 205 that didnt have that particular trait. Share this post Link to post Share on other sites
