Ant
2.0 Turbo Engine..running Lumpy
Ant
Ive spent the last month getting my turbo also sorted for MOT.. Finally got the VSS working and all should be well.. But... Its now ticking over a bit lumpy. It misses occassionally and the smoke from the exhaust smells very fuelly.
Ive disconnected the VSS but still the same. Thought it could be the battery as it has stood for a few weeks, so rechanged that and its still the same..
Any ideas ?
sonofsam
Hi Ant,
Possible lambda sensor not operating properly overfuelling it ?
Sam.
Guest frenchy205tt
Any ideas ?
hi mate i had the same problem i put a fse boost valve on and had a play with it but i dont run a lamba sensor or a vss and its runs realy wel now
Ant
Think it was a conbination of the lamba sensor and nippy weather before xmas. Swapped the sensor it all seems fine now :) Just need to get the MOT now :D
Cheers lads
