BossHogg 0 Posted November 22, 2007 (edited) First post and it's a question typical I have read the guide on how to lower the rear beam, just need to ask, the bolt needed to remove the plate from the radius arm is described as having a 19mm head and being at least 100mm long. Can someone tell me whether M30 would be the bolt i require? Edited November 22, 2007 by BossHogg Share this post Link to post Share on other sites
Guest smokinslim Posted November 22, 2007 Can't say for certain bout m30, but i do know that a ford wheel bolt is the right thread size and fit for the purpose. The following link takes you the search results for previous posts involving "ford wheel bolt": Clicky! This should provide ample further information on the subject if required. Share this post Link to post Share on other sites
BossHogg 0 Posted November 22, 2007 smokinslim said: Can't say for certain bout m30, but i do know that a ford wheel bolt is the right thread size and fit for the purpose. The following link takes you the search results for previous posts involving "ford wheel bolt": Clicky! This should provide ample further information on the subject if required. Thanks for that i have just been told its m12x 1.5 looks like i was MILES out lol Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted November 23, 2007 Best thing to use imo is a bendix front or rear caliper mounting bolt. I've had a ford wheel bolt shear off before so I no longer use them & GBendix caliper bolts are always laying waround on the floor at a scrapyard around Pugs. Graham. Share this post Link to post Share on other sites
