vern
Uprating Torsion Bars
vern
Will uprating the torsion bars prevent/alliviate the problem of the rear end squating down and the front end lifting under hard acceleration.
As currently when i accelerate hard the front end becomes very light and unstable.
Sandy
Yes, provided you fit appropriate dampers at the same time. This is one of the reasons uprating the bars is preferable to uprating the ARB.
vern
I have gaz adjustables, so they should be fine.
I don't want to go to thick with the bars, 21mm maximum as I only really use the car on the road. Will that be enough? to stop some of the problem.
Sandy
I would say so, I found 20mm bars worked really well on my 205 Rallye, much better than 18.9mm GTi ones for "fast road" use.
vern
Thanks for help Sandy.
RossD
Talking of 20mm bars, where can you get these from in 205 fitment?
Ross
205 Parts can supply them in any size you want. More details in the Group Buy section.
C_W
I would say you will get a good improvement by using stiffer shocks, not sure what you're running but some better shocks will prevent squat and front end lift on acceleration. I find my 205 doesn't squat so much; it seems the front lifts a bit but with Koni shocks all round it seems fine runnig standard torsion bars.
