24seven 104 Posted November 17, 2007 Does anyone know if this ECU is remappable or not? It's the one found on the 306/406 1.8 16v lump. Basically I don't want to have to get an aftermarket system to go with my mods, if I can avoid it (I don't know squat about ECU's, and electrics scare me). Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted November 18, 2007 I don't think it is remappable from reading a topic on 306 GTi-6.com (which you have posted on) & I couldn't find a definative answer anywhere else. The Sagem ecu has a known fault & you can get a marelli upgrade to fix. The Sagem SL96-9 ECU Most commonly fitted to 1.4 Peugeot, these ECUs suffer from voltage spikes caused by the sagem ignition coil pack. It could be worth give Wayne at chipwizards a call, he should be able to give you a definative answer about it. Graham. Share this post Link to post Share on other sites
24seven 104 Posted November 19, 2007 Cheers, will do. I got that impression from the 6 forum too, but generally speaking they don't like non GTi-6/rallye owners on there so I don't take most of it as definite answers. I'd rad about taht fault but I don't think I'm suffering it on my car. My stepper motor is on the blink as it doesn't idle right when cold (disconnect the stepper motor and the same problem happens when warm as well) so I'm gonna get that fixed as soon as I can afford a replacement. Share this post Link to post Share on other sites
