24seven
Brilliant 2row Ecu Guide
24seven
Ok so with this problem I've been haivng with my Mi16 not sparking recently I've been looking for a guide to the ignition system.
The other day I was randomly searching for pictures of BX's and was trying to see if anyone had had a go at the styling of them, particularly curious to see what may have been done about the rear wheel half cover thing. I found a website dedicated to BX19 16V's and on it was a download for a program called CAPS. It's got literally everything you need to know about the 2 row ECU found in the BX and the Mi16
I don't know whether or not this program is known by people on here, but at the off chance it's not, I thought I'd post it up anyway.
Enjoy!
Edit - see attached file as link above is dead.
caps.zip
Stu
Hurrah! ive been looking for the link for ages, this program has been an absolute godsend to me whilst fault finding.
MODS: I think this should be made a sticky somewhere as it is invaluable!
KRISKARRERA
Had that for years, but yeah I was orgasmic when I first saw it lol
kyepan
some motronic 3.1 info
the afm link has some good how to's on diagnosing problems using a volt meter, it also has nominal values.. good if your not too hot on electrics.
explains that the fuel pump relay is actually an accident / fuel not pumping relay
explains how to adjust the fuel mixture to cope with different petrol ratings 95/98 or adjust the mixture
j
RINRIN
I checked and this program is very good, but is this information suitable for my 205 XUJ9A. Especially the ECU pin numbers?
Not always, this is for the Motronic ML4.1 & M1.3 ecu's fitted to the XU9J4 Mi16 engine in either the Citroen BX 16v or Peugeot 405 Mi16.
If you have a 1.9 GTi with the XU9JA/Z 122bhp catalised engine then some of the information on the M1.3 will be relevent but not all.
RINRIN
Thanks I have 130bhp one without cataly. I understand that mine is L-jetronic.
But again the program is fantastic because of the instructions to check the components is shown
Edited by RINRIN
joris_andriesse
I do get an download, but can't run/install the program?????
timmsy19
not on a Mac by any chance? its a windows only program :(
joris_andriesse
No a normal windows pc. Can anyone else give it a try? So I will know ore the file is incorrect, or my pc is the problem.
ade 4wd
I have downloaded the CAPS program and installed it, and can confirm it works. :)
joris_andriesse
I got it installed now. Nut when I try to run it, it says "font file, not found".
Para
Is the program working now ?
24seven
Doesn't appear to work with 64bit windows as it's a 16 bit program, so I believe you'll need 32bit XP to be able to run this.
S@m
Had this for years, its was invaluable when i used the Mi16 as a daily driver (will be again soon).
Sadly i have recently upgraded to Win7 64bit so am currently working on a way to continue using it - maybe dosbox or somesuch, we will see.
Sam
Edited by Sam306
pixel.nine
Use a VMWare Player with a WindowsXP virtual machine! This will solve the problem! :)
S@m
VirtualBox seems to be the way forward for me at least....much the same as you said really. :)
Edited by Sam306
S@m
Just to tidy up an old thread, i am now using virtualbox (https://www.virtualbox.org/) to emulate WinXP 32bit on my Win7 64bit PC and it runs CAPS fine, is a quick and easy solution but bear in mind you need a copy of winXP to install on virtualbox.
Does anybody have a copy of caps.zip? I accidentally deleted the VM I had it in and now I can't find a working download link anywhere.
I should have a copy at home somewhere - I'll try to have a look tonight for you if I get chance :)
I should also have a copy if Anthony can't find his, I'll have a look through my old hdd's etc & reply with it (& update the original post with an attachment) soon as I can.
Found it and attached the file to the initial post at the top of the page :)
Thanks very much :)
Nice one Anthony, I've been through the old hdd where I expected to have it but it's not there.
I've got the old foldershare discs somewhere & I'm sure it would've been on there also.
g
Thanks for looking Graham :)
I'd forgotten about foldershare, that was a long time ago!
