Pob
Track Rod End Problem
Pob
Hi,
I noticed the boot on the track rod end was split so I decided to replace it. I had a real hard time removing the old track rod end... Took alot of heating and working it back and forwards, It gets really stiff to turn. I finally got it off, thinking the new end would be easy to tighten back in... I was very wrong, Its going to take the same method to remove as to refit, Any ideas whats going on? The thread on the end was fine. It took me over and hour to remove it, Surely it should be easy to refit :)
Thanks,
Dan
If its the right track rod end & the tie rod thread wasn't damaged it should've threaded in by hand imo.
Graham.
BERTMAN
whenever ive done it, i just wrapped a towel rnd the track rod and done it by hand so it dosent dig into your hands
can be a real b****** tho
boombang
Might be worth running a tap through the thread - if that won't go pretty easily, then might the thread is knackered (or someone cross threaded the previous one you just took out)
Pob
Thanks for the replies, I had to use a pipe wrench to hold the bar it was that tight. I'm going to get a tap tomorrow, am I right in thinking its 12x1.5? The thread on the end I removed was in perfect condition, no sign of cross threading. I'm going to run a tap through it, hopefully its just rubbish in the thread. Can you replace the rods? If so is it hard to do?
One last question, Is the rod treaded both ends so If I turn the rod it will adjust it within the boot if you know what I mean?
Many Thanks,
Dan
Edited by Pob
yup the rods are replaceable, I think GSF can supply them, they arent threaded at the inner end.
BuD
yes you can turn the rod to pull the track rod end on (with it attached to the hub) as it is a balljoint under the gaitor.
Its probably best to replace the track rod though, to do this remove the gaitor and unscrew it from the rack with a stilsons wrench.
Edited by BuD
Pob
Thanks for the replies... I decided to replace the rod, for the price of a tap and the chance it not working Its not worth the hassle. I was expecting it to be quite expensive, £10 + vat
Thanks everyone, a great help.
Dan
