madant_uk 0 Posted November 15, 2007 Does anyone know of anywere that sell these, i have seen a few places like Rally Design but they seem quite expensive at about £75 and was wondering is there like a cheaper but as effective tool that can do the same job to the same standard, because obviously you get what you pay for in most cases, hope someone can help thanks Share this post Link to post Share on other sites
brianthemagical 1 Posted November 15, 2007 please say it wasn't a rolson one. they are gash, and a waste of £7. the clampy thing doesn't have roundholes, it's that bad. Share this post Link to post Share on other sites
dani959 0 Posted November 16, 2007 There are some cheap (DRAPER) ones at Amazon. I got mine from there and worked a charm! Share this post Link to post Share on other sites
jord294 95 Posted November 16, 2007 hi. i recently bought a brake pipe flaring kit off e-bay as a 'but it now' for £30. made by 'laser' and even came with pipe cutter Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted November 17, 2007 from what i've seen, cheap ones can only do copper pipes, not OE steel ones. you may want to take a look at some high quality tools at http://www.toolsandhardware.co.uk . thanks. Share this post Link to post Share on other sites
Alastairh 47 Posted November 17, 2007 We will sort it Madant when im down sorting this loom. I've got use of a Snap on one, its so simple, its quicker than pulling a pint Share this post Link to post Share on other sites
Sandy 191 Posted November 17, 2007 The posher the better definitely! Cheap ones are inconsistent, leading to much wastage and frustration. Share this post Link to post Share on other sites
Simes 248 2 Cars Posted November 17, 2007 If you're replacing the 205 pipes then you could by a ready flared kit from Automec? Share this post Link to post Share on other sites
Alastairh 47 Posted November 18, 2007 sandy309 said: The posher the better definitely! Cheap ones are inconsistent, leading to much wastage and frustration. LOL. You can tell thats a man talking from experience. f***ing hate brake pipes Share this post Link to post Share on other sites
DaveW 6 Posted November 18, 2007 Yeah you can buy pre made kits for the 205. Share this post Link to post Share on other sites
Jrod 7 Posted November 18, 2007 It took me about 30- 40 flares before I could do them first time, just spent a while practising and now they seal 99.9% of the time. Share this post Link to post Share on other sites
djinuk 2 Posted November 18, 2007 my friend does them for free on snap on tool, but ive seen kits to do them but they seem useless Share this post Link to post Share on other sites
davev 1 Posted November 18, 2007 only ever used the cam type that you have to stick in a vice. works well on all pipes and can be used under car if you get someone to hold it in a large monky wrench Share this post Link to post Share on other sites
Guest smokinslim Posted November 18, 2007 The real cheapo kits on ebay are best left on ebay, they dont even grip the pipe tight enough to flare it properly, it slides through the clamp instead. If anyone wants one its theirs for the cost of postage Next one i got was about £28 posted, again from ebay. Much better piece of kit but still room for improvement. It'll even flare the cars original pipe. Share this post Link to post Share on other sites
Rippthrough 98 Posted November 19, 2007 (edited) Jrod said: It took me about 30- 40 flares before I could do them first time, just spent a while practising and now they seal 99.9% of the time. On a cheap tool? The old mopar tools are the best of the hand-helds - even an idiot can get a 99% seal rate, and someone with experience can get them spot on perfect centre every time, even in stainless steel, this rash of cheap ebay g-clamp tools are s*ite. Edited November 19, 2007 by Rippthrough Share this post Link to post Share on other sites
Jrod 7 Posted November 19, 2007 Mines Clarke. Problem I had was judging how much pipe to put through the clamp, to short and it didnt flare, to much and it went pissed. I can do them fine now. Share this post Link to post Share on other sites
Rippthrough 98 Posted November 19, 2007 Jrod said: Mines Clarke. Problem I had was judging how much pipe to put through the clamp, to short and it didnt flare, to much and it went pissed. I can do them fine now. See, mine has an indicator for that so it's spot on every time, apart from with stainless, which it wasn't designed for to be fair. Share this post Link to post Share on other sites
Anthony 1,003 Posted November 19, 2007 I use the Laser one mentioned near the top of the thread, and once I got the hang of it, I've had no problems at all and I've redone the complete brakelines on three cars with it now and never had to redo a single union Share this post Link to post Share on other sites
Anthony 1,003 Posted November 19, 2007 DaveW said: Yeah you can buy pre made kits for the 205. Only problem is that they're useless unless you're running a completely setup If you're running a disk braked beam on a 1.6 for example the rear lines are wrong. If you want to ditch the compensators, it's a faff with the Automec type kits as they're precut for compensators. If you want to convert the 1.9 diagonal split system to a front-back (like I usually do) then again, the pipes are all wrong. If you want to run an adjustable brake bias valve.... yeah, you get the idea. It's also much cheaper doing it yourself (about a quarter of the price I reckon) but admittedly does take longer. Share this post Link to post Share on other sites
nick 3 Posted November 20, 2007 I got mine from Machine Mart, £20 or so inc' a pipe cutter, I've done loads of flares with it and never ever had one leak. To get the correct length of tube, use the small pin (that slips inside the tube) on the end of the mandrel as a guide, hold it outside the pipe and leave the same length of pipe poking out of the clamp. Also, the end has to be absolutely square, so use the pipe cutters not a hacksaw. Nick Share this post Link to post Share on other sites
