Peetypug
Engine Warning Light!
Peetypug
the engine autodiagnostic warning light came on on my 306 this morning ;)
does anybody know how i can find out whats wrong without having to take it to peugeot?
it says in the manual that if it comes on while driving its either faulty operation of the injection, ignition or emmission control system
thanks
24seven
is tha the K light? mine comes on every now and then in my 306. Seen it come up for about 10 seconds before going away, about 3 times since I bought it at the start of august, 4k miles ago.
Edited by 24Seven
is it driving any different?
what engine is it?
24seven
think we've both got the same XU7J4. Mine drives fine apart from the clutch being a bitch, I suspect the flywhel is warped or something, and the ruddy stepper motor is a royal arseache.
Peetypug
its the 1.8 16v and nothing changed
there was no drop in performance no noises and i wouldnt have noticed it if i hadnt been coming up to a speed camera
the light stayed on all the way home and all the way to work last night
but this morning its gone off!!
it baffles me :P the airbag light was on the other week then that went off by itself
tipical bloody peugeot...... :)
Edited by sorrentopete
Longun
The ECU should still log what the error was so it could still be checked but I'd go somewhere with a general fault code reader rather than pug as they will charge the earth. I've always found with 306's the most common cause of a temporary error is the lamda sensor.
Henry Yorke
I know Gav at the Derv Doctor in Ashbourne has a good Snap on scanner that will tell you all this. My brother hasn't otherwise I would have said go there. You can get tose little Draper diagnostic tools yourself I think and they aren't much. I think possibly cat / lambda too and emissions
