Kennyb 0 Posted November 11, 2007 just refitting my fse valve, whats the correct psi i should be setting it at? Share this post Link to post Share on other sites
309PUG 2 1 Cars Posted November 12, 2007 just refitting my fse valve, whats the correct psi i should be setting it at? Set it to 3bar or 45 PSI Chris Share this post Link to post Share on other sites
Bally 4 Posted November 12, 2007 You mean throw it away and refit the std regulator. Share this post Link to post Share on other sites
Spiky 37 Posted November 17, 2007 Set it to 3bar or 45 PSI Chris can i assume, it's 3 bar from 1000 to 7500 revs? Share this post Link to post Share on other sites
welshpug 1,677 Posted November 17, 2007 nearly, there's a vacuum take-off to the intake manifold, so it depends on the variables how much fuel pressure you get. Share this post Link to post Share on other sites
brianthemagical 1 Posted November 19, 2007 the idea of the vacume bit is to give a constant pressure diffrnce between the inside of the manifold and the fuel rail, so there will be the same amout of fuel injected regardless of the inlet vacume. Share this post Link to post Share on other sites
